which intake manifold
Old May 5, 2009 | 12:08 AM
grey90stang's Avatar
grey90stang
Default which intake manifold
I have a 1990 5.0 with 4.10 gears, aod with shift kit, 70mm TB and spacer, BBK CAI, 73mm maf, electric fan, adjustable fpr, and full exhaust. I have 30# injectors waiting to go in and plans of supercharging it soon. What do you think the best intake manifold would be since i gotta pull it off to get to the injectors anyways? Thanks
Old May 5, 2009 | 03:19 PM
Portmaster's Avatar
Portmaster
If it has stock heads a Cobra intake will be all you need.
Old May 5, 2009 | 03:47 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
how many lbs of boost you plan to run?? 30lbs inj may not be the best if you wanna run alot of boost.
Old May 5, 2009 | 05:04 PM
kweb288's Avatar
kweb288
ya, with stock intake heads, and a novi 2000 set at 8-10#'s of boost i was told to go with 42# injectors... May want to rethink the injectors you have so you dont run out of fuel up top!
Old May 5, 2009 | 06:25 PM
NoGo95GT's Avatar
NoGo95GT
The Holley Systemax Intake will work well for boost. The GT-40 has it's limitations, the more power you have. You can run your 30lb injectors provided you use an FMU(It's what I use and it has worked well for me). Also, make sure you get a 255lph fuel pump.
Old May 5, 2009 | 06:31 PM
grey90stang
I was thinkin of just going with the typhoon intake and only running 6 pounds of boost. My Daily Driver
Old May 5, 2009 | 06:49 PM
NoGo95GT's Avatar
NoGo95GT
That setup will work fine too. But remember, once you get into boost, you're going to want more. I made 7psi stock and had to have more.
Old May 5, 2009 | 06:56 PM
grey90stang
Do you think heads, roller rockers, and the intake would be better than the supercharger?
Old May 5, 2009 | 07:00 PM
NoGo95GT's Avatar
NoGo95GT
Nope!!!!!!!!! Go boost first. I wish that is what I did. I did the H/C/I route first and was not satisfied. Plus installing the SC is waaaaayyyyy easier.
Old May 5, 2009 | 07:09 PM
grey90stang
Cool thanks for the info
