Timing question
Old May 8, 2009 | 12:11 AM
SonicBlueFiveSlow's Avatar
SonicBlueFiveSlow
Default Timing question
The big brown truck came today and brought me a bunch of goodies, including my cam(comp xe270), double roller timing set and harmonic balancer.
My question is, does #1 need to be at TDC to install the timing set? I brought it up to TDC and went to put the set on but the marks don't line up dot to dot. I rotated the crank and got the set to line up dot to dot, but when I put my balancer on, the timing marks are nowhere near the pointer. Am I ok or am I maybe 180 out on the stroke?
I'm not dumb, and this isn't the first motor I've messed with, but it has been awhile and I wanna make sure I do everything right.
Old May 8, 2009 | 12:33 AM
67mustang302's Avatar
67mustang302
The cam and crank gear only go on 1 way, except for the adjustable gears which have multiple placements. Select straight up, align dot to dot like the manual says....and then DEGREE YOUR CAM to make sure.
CarrieS
Sep 1, 2015 01:00 PM
GimpyHSHS
Aug 29, 2015 06:30 PM
Calizic
Aug 28, 2015 01:46 PM
stormesixx
Aug 25, 2015 09:11 AM
ding56
Aug 14, 2015 02:40 AM
