Well...well.well
Well...well.well
Sorry for the long thread but i need some help, ive got a few questions.....first i tore the intake manifold off today to find a noise in the lower intake that was rattiling, well i found it! the spider tray used to hold the lifters in place was rigged, because this isnt the same block that came out...its a non roller 302 bored over so the screw holes arent there my uncle rigged it to work...my first question is will vertical link lifters work in my non-roller 302 bored over to a 347? And now that i have a non-roller block is there anything else as far as differences between the two i need to know about??? Thanks again Jamison
I would be interested in seeing how he made it work aswell. As far as I understood it, you couldn't run roller lifters in a non roller block, not because of the spider, but the oiling location on the roller lifters verse the non rollers. I thought you could only use special lifters...
i order lifters from trick flow for my non roller block, they are a lil pricey but i can run any roller cam i want. comp cam also makes the lifters that work, they are called retrofit lifters. i havnt found any other differences between the blocks
http://store.summitracing.com/partde...t=LUN-72411LUN, Heres what im looking at now....they should fit right? all the h/c/i i bought obviously was for MY roller block but now there is too much b.s. to put up with so ill use what i got....
http://store.summitracing.com/partde...6&autoview=sku
http://store.summitracing.com/partde...8&autoview=sku
these i know will work, the ones you linkes to say they need some kit to work with a non roller block so im not sure how they work. also the one i posted are all hydraulic roller
