DS loop Q
Old May 20, 2009 | 10:53 AM
Tony71502's Avatar
Tony71502
Default DS loop Q
Does it matter where in relation to the driveshaft I install the loop? I've seen some people install one at front and one at the back. Based on NHRA rules or whatever, is two required?
I was just thinking of putting mine at about the mid point of the driveshaft.
Any thoughts on this?
Old May 20, 2009 | 10:59 AM
pass1over's Avatar
pass1over
The leading edge of the (2" wide minimum and minimum 1/4" thick strap) driveline safety loop MUST BE A MAXIMUM OF 6" behind the centerline fo the front U-joint.
as per NHRA rules. One is not required for the back joint, but it couldnt hurt.
Old May 20, 2009 | 11:00 AM
5.0stanger's Avatar
5.0stanger
You have to put it in the front like pass1over said. I think in the instructions that came with mine, it told me where to put it.
Old May 20, 2009 | 11:05 AM
hi_tek_rednek's Avatar
hi_tek_rednek
NHRA rules specify that the front edge of the loop be no more than 6" behind the front u-joint and at least 2" wide.(pg 67 in the 2008 rule book) on all cars running 13.99 or quicker using slicks or 11.49 or quicker using street tires. a second loop is allowed.
will...
Boostaddict
2.3L Eco-Boost Tech
Nov 24, 2015 06:11 AM
FivePointToTheOh
Sep 14, 2015 03:35 PM
dseg
AmericanMuscle.com
Aug 10, 2015 03:29 PM
import slayer
Feb 9, 2005 07:30 PM
TR4D
Mar 1, 2004 06:27 PM
