Rear drum to disc?
Rear drum to disc?
so i am looking to do a drum to disc swap/upgrade, there seem to be a lot of options. i am keeping the fronts stock so i do not need anything fancey. i ampretty sure i will need a different line bc of the difference in the placement of the discs? also i have heard about proportioning valves? do i need one? i there a kit that has what i need for a decent price? jegs has a ford racing kit for about $350 but it is just discs and calipers? any info would be great thanks mike
find a tbird turbo coupe rear end(1987-88) with factory 4 lug disc and go to this link
http://mjbobbitt.home.comcast.net/~m...tang/4lug.html
you won't need to buy new hard lines for the back but you will need to cut them and rebend them. on drums the hardlines go straight to the wheel cylinder but on the disc they will attach to a soft line.
yes a sn95 axle will work also from the same page i linked you
http://mjbobbitt.home.comcast.net/~m...n95brakes.html
thanks
yeah that page was good i appreciate it, i am pretty sure i am going to get new/used 94-95 calipers and discs in the rear and discs up front that will get rid of my drums and also get rid of my 4 lugs so i can put my set of cobras on it. thanks for the help mike
