TPS & Code Help!
Old Jun 4, 2009 | 05:55 PM
mynumber1hater's Avatar
mynumber1hater
Default TPS & Code Help!
90 GT 5.0, Check Eng light is on. So check the code....... code 53 TPS volts to high. So i tap into the green wire of the tps with my volt meter. And connect the ground to the body. It was a little high. So i adj it to (.99). turn everything off pull the batt cable reset codes. Start the car and check eng light comes back on. Now the code is 63 tps to low.. So i go back and forth with this for a hour. 1.0, .99, .98,.97,... same thing no matter what code 53 to high or code 63 to low...
Questions: Should i tap into the ground wire of the tps or is the body ok?
Is this a sign of a bad tps?
Am i doing the test right?
The parts house shows 2 or 3 different TPS for my car, how do i even know if the one i have is the right one?
Thanks Brian
Old Jun 4, 2009 | 06:53 PM
Joel5.0's Avatar
Joel5.0
Looks like the TPS is kaput or there's a problem with the SIGRTN circuit (you should use the black wire at the TPS as your ground reference point), or there's a problem with the TP wire (signal is intermittent at the ECM)........ BTW, no need to set the TPS at any specific value, as long as the closed throttle voltage is between .6 vdc and 1.1 vdc.... no TPS failure codes should show up. LUK
Old Jun 4, 2009 | 08:15 PM
mynumber1hater
I will see what i can do in the morning...(working nights) I wanted to take it to the track tomorrow.. But i dont know now. LUK
Old Jun 5, 2009 | 05:19 PM
mynumber1hater
New TPS fixed it right... no more codes...YES
Old Jun 5, 2009 | 09:03 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
in the future you can back prob the signal wire and with a dvom as you open the throttle, look for glitches/ opens, voltage should steadily rise and have no open spots......glad to hear it's fixed
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Dathan
Oct 5, 2015 05:52 AM
ChampInSD
Oct 2, 2015 04:55 AM
