Baseline Dyno Run
On Saturday I got the stang Dyno'd. 1991 LX hatchback. It's got 150k miles, burns a decent bit of oil, and has bad o2's. It has 275/40/R17s, 3.73s, and an aluminum driveshaft. It's also got MAC aluminum underdrive pulleys, shorties, 2.5" H pipe, 2.5" exhaust, timing bump, A/C delete, and some 1.72 rockers. Thanks to stock valve springs, the 1.72 rockers cause floating after 5300 rpm, so these runs stop just before that.
[img]
[/img]
[img]
[/img]
[img]
[/img]
[img]
[/img]
numbers are a little weak compared to mine but not too bad. i went to a dynojet as well when my car was stock to get a baseline with basically the same mods you have. all i had was 3.73s, bbk shorties, o/r h-pipe, mac mufflers, 12* timing, underdrives and a 75mm MAF for 19# which was making it run really rich, 11.6 afr all the way through
she put down 215rwhp and 274rwtq
do you have an AOD or 5 speed? mine is a 5 speed
