2 questions one thread...
your wasting your time!!! on my 92 the upper one is stripped and I was to lazy to drill and tap it, so I just used cork valve cover gaskets and bought a can of Permatex's "the right stuff" = silicon sealer or sort off...lol anyway that stuff is like glue, use it and I gaurantee they won't leak, I did just that and no issues
thats good to hear because for one im not pulling the vlave covers again other than when i replace the heads,cam and intake.also as long as it doesnt leak fine by me so i have the ford racing gaskets that are reusable and i have the car back together and im going to slap some silicone on it tommorow.i figure in about a year im doing my swap anyway.but thank you guys for the suggestions and help im sure ill be asking more questions
i forgot the size bit i used,...but i used the smallest easyout i had, and both(2) came right out after i set it in there and turned it, as well for me, the one that ur trying to get out is one of mine that i had to...but like mjr said, you can use that..but right now what im using is some cork gaskets and indian head to seal it up.....hope this helps, hope ya get it done and its up and running soon! good luck
i think that bolt snappedbecause it was really old and weak.but idid the sealtoday using the current gasket so ill seewhat happens and if i leakthen ill get the cork gaskets.i would pull the head but they are getting replaced a year from now anyway so im not bothering with it.i got the car running and all.i did my bbk offroad h pipe and damn that was such a pain in the ***.
i guess sometimes i forget this car is twenty years old so when you are trying to remove a pipe that has never been removed it does pose an issue.every bolt had to get soaked in rust penetrant and even the o2sensors were hard to get out.i also noticed that i had to cut the hangers off of the old h pipe to be able to drop it low enough to remove.i work at a shop but they have been having a fit about working on our own cars lately.today was definetely a day i wish i could have brought it to work to work on.ill tell you guys something,with the offroad pipe and stock mufflers it sounds really sick but im getting my flowmasters real soon.
believe it or not this car was practically unmolested.at least till the day i bought it.
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
