Another dumb balancer removal question
Please do not beat me up too badly on this one. How do you remove the 15/16" nut on the balancer without spinning the motor. I do not have an impact wrench, so I have to use what little brawn I have. Any help appreciated.
why cant you spin the motor?
as long as your turn it counter clock wise enough times it will eventually undo itself. i've never had it not do it. (tip: keep the spark plugs in, use breaker bar so you have leverage when turning the motor counter clockwise to make it easier on you, the compression made helps act as drag on the crank, giving you a chance to break the bolt free)
have all your plugs in? compression will help you
when you bring the breaker bar to where you can really put a ton of force into it...do it. try to turn of the motor fast when you get to a good leverage point. it will break free. might have to do it a few times.
09-10-2015 08:39 PM
09-08-2015 11:50 AM
