KOER----6cyl?????
Old Jul 10, 2009 | 07:40 PM
gt884me's Avatar
gt884me
Default KOER----6cyl?????
I gotta run but ill be back....ran a koer test because my car seemed to be slacking...My OBD tester first checks for # of cylinders under test before all tests and it came back 6....wtf? Why? Also the only code i could come up with that seemed out of place was 94....Well where do i start for the 6cyl issue?..Thanks all, Jamison
Old Jul 10, 2009 | 07:48 PM
smacked1's Avatar
smacked1
hey quick question i was running my actron obdi scanner on my 91 5.0 and kept getting a connection error after each test and it would ask me to restart or no im lost =(
Old Jul 12, 2009 | 08:01 PM
gt884me's Avatar
gt884me
No-one has ran into this????
Old Jul 12, 2009 | 08:39 PM
Joel5.0's Avatar
Joel5.0
Set the scanner aside, run it using a test light and check how many flashes it outputs when it is initiated. The problem may be a scanner problem....BTSTDT. BTW.... the engine cylinders ID code is an informational code, not a failure code. LUK
Old Jul 12, 2009 | 08:52 PM
FivePointOhh's Avatar
FivePointOhh
in limbo
could it ID 6 cylinders and there not be a problem? i ask because ive been helping jamie with this car and it runs just fine...(accept for the transmission )
Old Jul 12, 2009 | 08:54 PM
gt884me's Avatar
gt884me
Well besides that i did a koer and had a few codes like the thermactor crap that i removed but i noticed my total timing is not changing from my base timing.....got any idea why?
gt884me's Avatar
gt884me
Yeah tranny is gone
Old Jul 13, 2009 | 10:02 AM
AdderMk2's Avatar
AdderMk2
Banned
if your total timing does not change from the base timing set with the spout removed, then you could have a broken SPOUT wire between the distributor and ECM
Old Jul 13, 2009 | 10:20 AM
FivePointOhh
in limbo
keith, the total timing changes when you plug in the spout...but only like 2-6 degrees. not 20 like it should. still think it could be spout wiring is bad?
