Constant Electrical Drain......Help!!!!
Old Jul 19, 2009 | 05:29 PM
enfausn's Avatar
enfausn
Default Constant Electrical Drain......Help!!!!
got a 89 LX 5.0 with a continual drain. didn't start her for about a week cause i was out of town for work and sure enough the battery was dead as a door-nail. Once I got it jumped I am getting 13 volts so the charging system is working fine. I'm guessing I've got a short somewhere that's hot all the time. It stays charged enough to start up fine as long as I run it every couple of days. I;m checking all the usual suspects like the hood light, trunk light and battery cables. But, electrical is far from my strong point so I was wondering if anyone had chased on of these buggers before and had any hints that might help me to keep some of the hair in my head..LOL! I just bought this car about a month ago and it had a new battery and a new alternator so I'm wondering if the prior owner was chasing the same problem and just was chucking parts at it. Any help would be greatly appreciated. Thanks!
Old Jul 19, 2009 | 06:52 PM
Bubba 95SN's Avatar
Bubba 95SN
Disconnect pos bat cable hook dvom between bat and cable read voltage drain. Pull fuse from box until drain goes away. Check that circuit. Remember to close door between readings or will have dome light being volt drain. Still have drain and all fuse are out. Take fusible link that goes to alt off starter relay. Drain goes away you have bad diode in alternator. You can substitute 12v test light for dvom but for the price can get one at Sears fot $15
Old Jul 19, 2009 | 11:28 PM
jjw88mustang's Avatar
jjw88mustang
this is what i used, it turned out to be my cigarette lighter
http://flashoffroad.com/electrical/B...teryDrain.html
Old Jul 20, 2009 | 04:19 AM
enfausn's Avatar
enfausn
Thanks for the info guys.........Just needed a good starting point. Thanks a lot!!!!
Old Aug 16, 2009 | 06:21 PM
enfausn's Avatar
enfausn
thanks for the help everyone...........I found it. It was the hood light of all things.....LOL. thanks for pointing me in the right direction
Old Aug 16, 2009 | 09:04 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
glad to hear you solved it
ChampInSD
Oct 2, 2015 04:55 AM
LiquidDrink
Sep 29, 2015 10:06 AM
mrappe
Sep 26, 2015 10:16 AM
Ford_Dude
Sep 15, 2015 03:25 PM
TfcCDR
Sep 14, 2015 12:08 PM
