Distributor problem
Old Jul 21, 2009 | 10:55 PM
eddies92lx's Avatar
eddies92lx
Default Distributor problem
Ok went to the dyno again and had to bump up my timing to 30* to make power(350hp and 400tq). So I think that my distributor is off a tooth. So I need to pull it and drop it back in. What is the best way to make sure the engine is at top dead center?
Old Jul 21, 2009 | 11:12 PM
AdderMk2's Avatar
AdderMk2
Banned
piston stop screwed into the spark plug hole
Old Jul 21, 2009 | 11:26 PM
eddies92lx's Avatar
eddies92lx
Ok not to sound dumb but what is a piston stop adder? I work at a parts store and have never heard of one. I mean the name obviously give away what it is I have just never seen one.
Old Jul 22, 2009 | 08:27 AM
TrimDrip's Avatar
TrimDrip
FudgeDrip
I still fail to realize how a tooth off can't be corrected by turning the distributor.
To install it correctly, Get someone to help you find the compression stroke. You should see your timing mark somewhere around there. With the balancer at tdc your rotor button should be pointed towards the #1 plug wire.
Maybe you need a distributor
Omgitsa88Stang
Oct 5, 2015 07:33 AM
StalkerGT
Sep 25, 2015 02:41 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
jaiidutch
Sep 14, 2015 10:29 AM
