2,000 to spend
07-27-2009, 10:53 PM
D.R. THE PATHETIC DORK
3.73's or 4.10's pending the tire choice
07-27-2009, 11:03 PM
4.10 gears, man up about it.
Some good tires for the rear.
I doubt if there will be enoght left fot H/C/I/.
Go for the heads.........
07-28-2009, 12:36 PM
i wouldnt mind some tires but the question is whats the best bang for buck for tires, lets say if i get the 4:10 gears how wide can i go on the rear? and what heads whould you guys suggest, if not intake?
07-28-2009, 01:19 PM
in limbo
430 gears, 28" tall drag radial, the rest spent on suspension. you'll thank me later when you hit a high 12 without touching your motor.
07-28-2009, 05:33 PM
start with gears then do h/c/i but no letter cam is what mjr was sayinf
07-28-2009, 07:08 PM
The Rogue Mod
Quote:
Originally Posted by
stevebrack23
what you have
2 grand as soon as you send it to me!!
stevebrack23
goal is maybe high 12's
Why stop there!!
07-28-2009, 08:16 PM
If I had $2k it would be subframe connectors, gear, h/c/i..
Or save another $1K and get a sv650.
07-28-2009, 09:11 PM
if no letter cam. where should i get it from and what kind of cam
07-28-2009, 11:09 PM
Skip the cam and H/C/I. Go BOOST!!! You can find some good used superchargers for cheap over on the Corral, especially for the Fox Mustang.
07-29-2009, 01:21 PM
Rear Gears- 3.73 if you drive on the highway
Clutch or Torque Converter- if you planning on racing it, TC helps for drag racing launches
Cam and Valvesprings- E303
OR
Save up a little more and buy a centrifugal supercharger.
