can anybody tell me???
noone can accurately give you any numbers.
what CI do you have?
heads?
cam?
full bolts on? if so which ones?
i guess what i am saying if you had a restriction before hand this would allow the motor to flow a little bit more air
heads?
cam?
i have the edelbrock intake manifold, headers,cold air intake,70mmbbk throttle with spacer,ported stock heads with an iskie cam awell as some roller rockers..dnt know wut kind of rockers i bought them off some guy i met and he jipped me..but they work the the rockers have inscribed f16..i dont know wut that is..and its a roller cam. i have an x pipe with magna flow mufflers..and 3:55gears.
Sadly he is correct. Stock 5.0's have always come with **** for cylinder heads. Therefore, no matter what bolt on's you throw at it, you will not pick up much power till you upgrade you cylinder heads.
These things aren't LS1's.........
