anyone actually fix the BBK TB "stick"
Old Aug 5, 2009 | 08:53 PM
nacanitihs's Avatar
nacanitihs
Default anyone actually fix the BBK TB "stick"
the initial stick of this 70mm BBK TB is really startin to **** me off.. its hard to just start off easy as you need to apply a decent amount of pressure just to get the damn thing to start opening. after that its real easy to move. also while cruising im constantly having to blip the throttle or it kinda acts like cruise control.. hanging around 2k rpm.
so did anyone actually fix this issue before? ive heard its a common problem with these bbk tb as well as the whistle but i already fixed that.
i was thining about trying to lube the throttle cable but i couldnt seem to find anywhere to actually spray inside the cable casing.. any ideas on that?
thanx guys
Old Aug 5, 2009 | 10:09 PM
AdderMk2's Avatar
AdderMk2
Banned
unscrew the butterfly plate and remove it.
gently sand down the edges, round them out
Old Aug 5, 2009 | 10:15 PM
nacanitihs's Avatar
nacanitihs
ill try it
Old Aug 5, 2009 | 10:56 PM
AdderMk2's Avatar
AdderMk2
Banned
if you look inside, you should be able to see where its getting hung up, I know my new 75mm did it
Old Aug 6, 2009 | 05:57 AM
5pointslow91's Avatar
5pointslow91
never had a prob w mine
Old Aug 6, 2009 | 05:32 PM
nacanitihs's Avatar
nacanitihs
well adder i did what you said and now the "stick" is gone but now the whine is back... FML
i guess i can deal with that versus drive ability issues
Old Aug 7, 2009 | 10:40 AM
projectresto83's Avatar
projectresto83
M.A.D. Motorsports
How did you deal with the whistle before?
Old Aug 7, 2009 | 07:22 PM
nacanitihs's Avatar
nacanitihs
bored out the IAC opening. there was a lot of sharp edges and roughness causing the whistle
4cylinderplus2
Oct 9, 2020 07:45 PM
bradleyb
Nov 27, 2015 07:50 PM
jerrytubes
Oct 23, 2015 12:11 PM
ChampInSD
Oct 2, 2015 04:55 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
