Input Shaft
Old Aug 7, 2009 | 06:55 PM
jjw88mustang's Avatar
jjw88mustang
Default Input Shaft
I just pulled my manual transmission out and was wondering how much top to bottom play should be in the input shaft. Back and forth its fine but up and down it seems to have a little play.
Old Aug 7, 2009 | 07:35 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
that's normal
Old Aug 7, 2009 | 08:17 PM
jjw88mustang
alright, any tips for getting the pilot bearing out? I tried a puller and it just ripped the center out.
Old Aug 7, 2009 | 08:32 PM
mjr46's Avatar
mjr46
if your using a little slap hammer, whicj is what I use and it has two fingers that grab two flats on the inside of the pilot bearing...a few slaps and it always comes out as long as I gave the fingers tight enough
Old Aug 7, 2009 | 11:23 PM
67mustang302's Avatar
67mustang302
That's also why you should coat the outside of the new pilot bearing with a little antisieze, that way they go in and come out relatively easily.
Old Aug 8, 2009 | 05:06 PM
sn95_331_GT_ yellow's Avatar
sn95_331_GT_ yellow
old school trick is to fill the hole with grease and then use a hammer to push a wooden shaft in there. the shaft moving in (heh, heh, giggity) will force the grease behind the bearing and move it out a bit. dont use metal because it will (obviously) cause problems.
Old Aug 8, 2009 | 09:09 PM
Bubba 95SN's Avatar
Bubba 95SN
Wet paper towel or toilet paper if you run out of grease....not as much trouble to clean up.
bradleyb
Nov 27, 2015 07:50 PM
Dokilar
15
Oct 16, 2015 08:13 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
guitarman376
Sep 30, 2015 05:54 PM
dudeguy421
Sep 24, 2015 11:16 AM
