injector size???
can anyone tell me how if possible to tell what size injectors are in a car 89 mustang 302 with no crazy mods just cold air intake, svo heads, cam (f303 i think), full exhaust, ignition, chip, underdrive pully. my plugs are white and i've gone over and over everything only thing i can think of is maybe injectors are blocked or are to small i would like to step up in size if it would make more power and fix this problem.
iirc, stock (19#) is yellowish orange and 24s are blue. with the mods you have, i would run 24s. once you upgrade h/c/i, even if its a mild combo, its a good idea to upgrade to 24s
you might also want to look at your pump. when i did heads and intake on my motor i did 24# injectors and went to the track. ran the wide band and it says i was 22:1 afr. i increased the fuel pressure every pass till i hit 55psi and still was getting a 20:1 afr. thats when i realized the fuel pump just couldnt keep fuel pressure up at higher rpms
whats the best way to check both i have a fuel pressure gauge what or how do i do the rest ?? also car was set up like this for the last 3 yrs and plugs looked good is it possible that changing plugs from autolite to motorcraft affected this??
dumb as a rock when it come's to fi
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
