reverse and turn signals wont work
Old Aug 23, 2009 | 04:39 PM
bigt8156's Avatar
bigt8156
Default reverse and turn signals wont work
Hey Guys need some help here, I just bought a 90 mustang gt. The reverse and turn signals wont work. I have changed the flasher cannister and the bulbs out. Still nothing hazzards work thou. Any Ideas please feel free to give me your suggestions, Thank you in advanced..
Mustangs Forever, Forever Mustangs
Old Aug 23, 2009 | 05:11 PM
mattdel's Avatar
mattdel
reverse lights most likely the switch on the transmission. turn signals most likely the multifunction switch. either drop some cash or break out the multimeter.
Old Aug 23, 2009 | 08:33 PM
bigt8156's Avatar
bigt8156
I switched out the multiswitch after I posted still nothing. I broke out the manuel and it says that the turn signal cannister is on the fuse support frame but I have had no luck in finding this. Thanks for your help will have to crawl under the car for the reverse light switch.
Old Aug 23, 2009 | 09:14 PM
SonicBlueFiveSlow's Avatar
SonicBlueFiveSlow
There's 2 flashers, one for the hazards and one for the turn signals. The one for the hazards is near the fuse box and the one for the turn signals is behind the glove box, which one did you change out?
Old Aug 23, 2009 | 10:57 PM
bigt8156's Avatar
bigt8156
I changed out the hazzards the one in the fuse box. The chiltons manuel is way off it was telling me it was on a fuse support post. Thanks for the heads up I will look behind the glove box.
Old Aug 28, 2009 | 10:49 PM
bigt8156's Avatar
bigt8156
Smile
Thanks SonicBlue for the good advice. I went to the Junk Yard today to get a new wiring harness because the guy who had the car before me butchered the thing trying to put in a homemade start button. The very first thing I did was to remove the glove box and there it was. So thanks again for the heads up.
P.S It took me 3hrs to remove the harness in 110 degree heat....
djbigskrilla
Sep 20, 2022 01:04 AM
movielover40
Aug 27, 2015 03:26 PM
kdryan
Aug 21, 2015 04:01 PM
bigdaddy51200
Aug 19, 2015 05:09 AM
cema93
Aug 10, 2015 09:35 PM
