exhaust
any one kno where i might find i full stock exhaust or even parts like the manifolds, h,x-pipe catbac-setup. i need the used stuff cause im trying to get a project car i have to pass a safety but unfortently i dont hhave the exhaust so if anyone has the used exhaust parts laying around let me know and we can see if we can work something out or maybe some one can point me in the right directsion for 86-93 stock exhaust. thanks
I doubt you will find a stock cat-back especially in Ontario, but you probably could find the stock headers and mid pipe if you check around on kijiji and craigslist. I still have stock headers, but they are seriously not worth spending money to ship across the country. You should just invest in a full exhaust system, 150 for headers, 150 for an h-pipe and depending what you run for a catback 100-300 dollars.
well see my street/strip motor i have 408 is being pulled and well its out im put my 302 back in one problem is that i have to have a safety done in about 3 weeks so i'm trying figure out what im going to do for a exhaust system. my race motor just has mac 3" dumps with off road h-pipe
The problem with finding a stock cat-back is if used, they are always cut right before the axle in order to be removed. And if you find a new kit, you will be paying a pretty penny for it. Just use a quiet turbo catback to suit your needs.
I am going to put longtubes on when they come in. I would let you have the stockers for cheap.
The h-pipe is a little harder to come by because the material in the converters brings good money at the scrapyard. You may luck up and find someone that doesn't know that and let you have it for 50 bucks. I will be taking mine to the scrapyard.
Any cat-back will be rusted through most likely and you will have to go aftermarket. I could let you have the lx pipes for cheap. They will be cut though.
Sep 30, 2015 12:39 PM
junior04
Sep 28, 2015 10:53 AM
Sep 24, 2015 09:18 PM
