speedo help?
Old Oct 16, 2009 | 08:35 PM
hypertruejedi's Avatar
hypertruejedi
Question speedo help?
the story thus far.... i bought my 1985 5.0 H.O stang from a guy about 4 months ago. when i drove it home and tore into it to see what was wrong with it (which turned out to be various things...) i realized that the car had no pilot bearing. after a clutch, flywheel, pilot bearing and throwout bearing install/reinstall the car seemed fine. a few months later the tranmission began to make noise and eventually stripped 7 teeth off of third gear. i traded off the busted t5 for a virtually new t56. i did my homework and this seems like a really good tranmission. the only problem is im not sure if the gear inside the transmission for my speedometer will match the one on my cable. my motor is out having machine work done or i would simply install the trans and find out for myself. does anyone know if the gears match for an accurate speedo reading, and if not where i could get a gear that would work?
Old Oct 16, 2009 | 08:55 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
this should answer your question:
http://www.musclemustangfastfords.co.../pictures.html
67LimeCoupe
Nov 25, 2015 08:55 PM
Mr. D
Tuner Central
Aug 27, 2015 05:01 AM
Mr. D
Wheels & Tires
15
Aug 22, 2015 02:58 PM
Gregz
Aug 11, 2015 03:42 AM
qwikhuh
Dec 1, 2003 04:26 PM
