different crankshaft metals
Old Oct 17, 2009 | 10:56 PM
motorman524's Avatar
motorman524
MF Informant
Default different crankshaft metals
I bought a TKO 600 so I need my engine rebalanced. Right now I have a used Mountaineer crankshaft that I had reconditioned. I want to give the machine shop a new crankshaft instead of this one because I plan on supercharging and I want to make sure that the bottom end is solid. Would a cast steel Crankshaft be adequate? I have been reading on forged steel crankshafts and they seem like overkill. Also, I am not sure what the Mountaineer crankshaft is made up of so if anyone knows , I would appreciate it.
Old Oct 17, 2009 | 11:35 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
a motor isn't rebalanced cause you buy a new tranny, and no need for a crank that'll out live a stock block , cause what's worse when the motor lets go, losing a 200 dollar crank or a 1000.00 dollar one??? exactly!!
Old Oct 18, 2009 | 12:02 AM
67mustang302's Avatar
67mustang302
Yeah, block will fail before a stock crank even. And yeah, why are you rebalancing the engine?
Old Oct 18, 2009 | 12:08 AM
motorman524
MF Informant
I'm not going to re balance it because of the transmission, I'm going to re balance because I am using a different flywheel. It is an auto to man conversion. I can definitely see your point on the crankshaft. Do you happen to know what this stock crank is made up of?
Old Oct 18, 2009 | 07:24 AM
projectresto83's Avatar
projectresto83
M.A.D. Motorsports
You don't have to rebalance the crank when you do the auto to man conversion either there buddy.
Old Oct 18, 2009 | 07:35 AM
mjr46's Avatar
mjr46
^^^^^what he said, as long as it's a 50 oz motor, no need to
Old Oct 18, 2009 | 10:31 AM
projectresto83
M.A.D. Motorsports
and if it is the stock motor in your car then it is a 50 oz.
Old Oct 18, 2009 | 01:01 PM
motorman524
MF Informant
I had the engine balanced before. It was bored to 306 because I had some scoring in a couple of cylinders. I have sealed power forged pistons and forged eagle rods. Block is in great shape according to the machine shop. No cracks, or anything. That's why I want to make sure that I have a crank that will last if I supercharge.
jrrhd73must
Oct 2, 2015 09:17 PM
KingRando
Oct 2, 2015 08:06 AM
UrS4
Sep 30, 2015 10:13 AM
mungodrums
Sep 28, 2015 10:54 PM
mrappe
Sep 26, 2015 10:16 AM
