I read about ponyboy302 problem so if you only remove the front oil pan plug and not drain the back plug,how much oil is still going to be in the pan yet? I never new they had 2 plugs..............thanks
Honestly if it pains you to remove two plugs instead of one, you should just take the car to the dealer for service. 5.0 is one of easiest cars to change oil on. Both plugs are easily accessible and in clear view, and filter is accessible from the top.
