Valve Spring Help
Old Nov 15, 2009 | 10:04 AM
stang8689's Avatar
stang8689
Default Valve Spring Help
I dont know much bout valve springs I dont know total lift and all that was just told I should upgrade my springs. i have AFR heads with the factory .550 max lift springs. I am going with a comp cams XE270HR-14 cam and 1.7 roller rockers. So do i need to upgrade my springs? Comp cams has 2 recommended springs for $70 here is what they have if i need springs which ones?
Cam http://www.summitracing.com/parts/CCA-35-351-8/
springs http://www.compperformancegroupstore...Category_Code=
Old Nov 15, 2009 | 10:09 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
I'd use the 986's, I have a set if interested
Old Nov 15, 2009 | 07:37 PM
stang8689's Avatar
stang8689
what else what I need do I need retainers and locks?
Old Nov 15, 2009 | 07:40 PM
mjr46's Avatar
mjr46
springs, retainers and locks , if your afr heads have locators already you can reuse those, all locators do is give the spring a hard seat to rest on which all OTB aluminum heads should have
Old Nov 19, 2009 | 09:20 AM
stang8689's Avatar
stang8689
so if I was buying brand new would I be better off with the 986 or the 987 thanks
Old Nov 20, 2009 | 05:12 PM
stang8689's Avatar
stang8689
bumppp
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mrtrodonet
Sep 19, 2020 03:12 PM
CS2007
Jun 25, 2019 09:45 PM
mungodrums
Sep 28, 2015 10:54 PM
