Dexcool in a 5.0
Old Nov 15, 2009 | 08:54 PM
93stallion302's Avatar
93stallion302
Originally Posted by mjr46
well ,the way a gm rep explained it to me in a class I had a long time ago, not sure if it's true or not but the compound make up of dexcool reacts with the metals and gasket material and deteriorates it over time when dexcool is exposed to the atmosphere, via leaks.......it also sludges if not serviced at proper intervals, the 3.1 and 3.4 intake gaskets were of plastic and rubber construction and over a period of time and numerous heat cycles coupled with the dexcool reacting with the materials they deteriorate and spring leaks in the corners, the worst one I did was a malibu last year, when I removed the intake the leaks had sprung internally and had plugged up the oil drain back holes in the heads and filled the intake with globs of soft pasty sludge due to mixing with oil, we used a special air powered suction gun and funneled the crap into a paper bag, what a mess!!!
I see thx for the explanation. Sounds like fun
Old Nov 16, 2009 | 05:53 PM
lxman1's Avatar
lxman1
I have done numerous Blazer water pumps and radiators due to that crap as well. It is a mechanics friend
Green/yellow or go home!!!
Old Nov 17, 2009 | 08:24 AM
FivePointOhh's Avatar
FivePointOhh
in limbo
lol mike, i hate dex-cool, but it makes me money too i've done like 2 head gasket replacement due to the stuff and 8 intake gasket swaps in the past few months. you should know cause you helped me figure it out the first time i came across that crap :P
Granatelli Sales
Mar 25, 2016 08:01 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
mungodrums
Sep 28, 2015 10:54 PM
treesloth
Sep 28, 2015 07:03 AM
