nitrous question
Old Nov 25, 2009 | 10:46 AM
FivePointOhh's Avatar
FivePointOhh
in limbo
ok i got the kit.
what window switch should i get? i'm looking for ease of application, digital perferable...i dont like those little pill type things. can anyone provide links?
Old Nov 25, 2009 | 10:55 AM
primetime5.0's Avatar
primetime5.0
go to nitrousoutlet.com, I would look into getting a window switch with a gear lockout
Old Nov 25, 2009 | 10:59 AM
FivePointOhh
in limbo
what is gear lock out? makes it so it doesnt spray WOT in 1st gear?
Old Nov 25, 2009 | 11:06 AM
FivePointOhh
in limbo
is there a chart for jet sizes to figure out wtf size i need for nitrous/fuel. like a ratio or guideline chart?
thanks for the link, i like that window switch. cheaper too
also i'm running HCI on 19# injectors. with a wet kit do i need to worry about running on 19lbs injectors or will i be good because i'll already be added extra fuel to the mix?
Old Nov 25, 2009 | 11:15 AM
primetime5.0
correct, if your on street tires it'll just blow them off.. spinnin aint winnin
Old Nov 25, 2009 | 11:17 AM
primetime5.0
I dont have a chart right now, ill look when I get off of work,
If you have a big pump in the car you should be fine
Old Nov 25, 2009 | 11:21 AM
FivePointOhh
in limbo
i have a 190 fp iirc. should be good enough.
although im chasing some pressure demons right now. it wont hold pressure longer than 15 seconds after shut down. i cant find any leaks and the pump is new. i shouldnt be having leak down like this. ughh...
Old Nov 25, 2009 | 01:22 PM
302army187's Avatar
302army187
get a bottle heater.
even with a bottle heater i have to wait 5-10min some times for good bottle pressure.
a full bottle will be at good pressure really really quick, but even a half bottle can take 10min+ to get up to pressure.
Old Nov 25, 2009 | 02:15 PM
nacanitihs's Avatar
nacanitihs
here is the zex one
http://www.compperformancegroupstore...Category_Code=
if you get the n2o outlet one lmk how it works i need one. i dont wanna run a button.
302army what setup do you use?
Old Nov 25, 2009 | 02:25 PM
302army187's Avatar
302army187
set up as far as what?
I have a WOT switch that attaches to my throttle body.
