get the a head cam intake combo that will respond well to boost and build the motor like that first. do it all at once! it would be a pain to keep taking the motor apart to install them separately.
u were asking about the gt40x heads. look at my sig
no, im saying that if you are going to change the heads... do the cam and intake at the SAME TIME
ok
Originally Posted by mjr46
also get the car running good N/A before slapping a s/c on
ok i have the right idea then
ok so th eafr 165's make more power then the gt40x's
and whats the diff with the afr 185's(wount they make even more power??)
the 185's arent emissions legal. they also have 2.02" intake valves which will require you to get your pistons fly cut depending on your cam selection. and they wont necessarily make more power on an n/a 302 but boosted, they would have an advantage
