CAI Opinions needed
^^^THAT'S ALL RIGHT NO BIG DEAL I'll most likely get the bbk one and if this meter doesn't work then I'll give you a call, i CAN PULL MY UPPER INTAKE IN 15 MIN OR LESS so swapping inj's is no issue
I went with the MAC fenderwell CAI Part # 3693
FWIW the Mac has an EO # also.
http://www.macperformance.com/store/...Product_ID=191
http://cgi.ebay.com/ebaymotors/MAC-3...Q5fAccessories
also, mike.. take the chip and the 24#ers out and drop bernies 19#ers in there. you should run that chip until you can verify what kind of info is even in it. Its likely that the chip doesnt have a 24# tune in it, and the PO might have bought the maf off ebay as a "cobra maf" thinking that it would run the 24#ers.
use the SN maf (as long as its a F2VF) and run 19# injectors with no chip.
I use the BBK and there is really no need for the stand, Everything is pulled really tight.
No sag and it doesn't come loose anywhere. I was mad about that too but I checked it and gave everything a good tug, tried to move it some, nothing seemed to want to go anywhere so I'm not worried about it(right now anyway).
