Electrical issues
Old Dec 4, 2009 | 08:22 AM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
Default Electrical issues
I have a friend thats having issues with his electrical system in his 94 gt.
Thought it was the battery, but it read 14v until the high beams and fan was turned on, then it dropped to around 12v. At idle the lights dim considerably bring the rpms up and the lights brighten back up. Alternator was tested at 60 amps.
Car is like Elanor cranks when it wants to, but everything appears to be fine.
His mods
CAI
UD pulleys
Old Dec 4, 2009 | 08:28 AM
FivePointOhh's Avatar
FivePointOhh
in limbo
check your electrical grounds.
engine ground, battery ground, ecm ground.
Old Dec 4, 2009 | 08:58 AM
USMCrebel's Avatar
USMCrebel
i'll have him check those, what about regulators would that be good to check?
Old Dec 4, 2009 | 09:19 AM
FivePointOhh
in limbo
the alternator regulator would cause the voltage to jump all over the place if you jam on the gas pedal causing the battery to over charge for the time you have the pedal floored.
Old Dec 4, 2009 | 12:06 PM
AdderMk2's Avatar
AdderMk2
Banned
His mods
CAI
UD pulleys
The alternator is junk, take the UDP'S off and replace it. 94-95's have a 130 amp alt.
check grounds near the battery, check the ignition switch, and check for voltage drop at the stater.
Old Dec 4, 2009 | 12:34 PM
tdowden1's Avatar
tdowden1
Will the under drive pullies hurt I have heard thiis is normal for a 94-95 with them especially when it gets hot... but as long as it is driven 2 to 3 days a week the battery should stay charged good enough to start it..
Old Dec 4, 2009 | 01:44 PM
USMCrebel's Avatar
USMCrebel
good now he is here to explain the issues
chrisdbassplayer
Oct 13, 2015 06:53 PM
Dathan
Oct 5, 2015 05:52 AM
LiquidDrink
Sep 29, 2015 10:06 AM
mrappe
Sep 26, 2015 10:16 AM
jc409
Convertible Tech
Sep 26, 2015 08:28 AM
