ok help is needed(upgrading engine)
Old Dec 10, 2009 | 01:33 PM
XPBaller's Avatar
XPBaller
Originally Posted by mjr46
^^^^^you can also boost the snot out of a stock long block and with a few bolt ons hit the mark too.....as xballer stated there are many ways to do it, just depends on what you want, I went custom cam and eddy rpm heads with the small 1.90/1.60 valves and ported upper and lower cobra intake as well as all the normal bolt ons and this thing screams, I'd be suprised if it's not close to the 300 rwhp mark already
It'll hit 300 NO PROBLEM mjr... I'm running the old ped mount eddy rpm 1.9 heads with a cobra intake too. Only difference is, my cams on OTS comp cam, and my cobra intake isnt ported. The car hit 282WHP UNTUNED on 12* timing with WIPED OUT MAINS. 300 for you shouldnt be a problem
Old Dec 10, 2009 | 03:06 PM
newpony's Avatar
newpony
thats rear wheel hp ?....
whats hp lost % from crank/flywheel to wheels
Old Dec 10, 2009 | 03:12 PM
newpony's Avatar
newpony
Default muti post yes i know mybad
400 AT THE CRANK??? worry about what hits the pavement as all you'd need to hit that mark is a good h/c/i and a dyno tune which will equate to a little over 300 rwhp.......12-14 psi will not blow the block, ask PRO50SC he has 375 rwhp on a stock long block with a few bolt ons and 12-14 psi and his block has 160k, fuel system and a tune will be key
hhmm what do you think about this ...then gt40x heads(no piston notching needed right) and a really good set of push rods/valve springs/rocker arms
with my current setup of couse with the the added charger@12psi+
Old Dec 10, 2009 | 04:41 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
SO you'll be using a stock intake and cam??? if so with just adding heads, you should come close to 400 rwhp easy, but I'd at least add an intake to complement the heads, stock cam should allow you to make enough steam
Old Dec 10, 2009 | 05:11 PM
DeltaElite121's Avatar
DeltaElite121
If you haven't chosen the heads yet, I would go with Trickflows. They've been really good on plenty of Fords, and I've actually got a set on my 383 SBC in the Camaro. The finish on them is usually top notch as well. Just my opinion, though.
Old Dec 10, 2009 | 06:54 PM
newpony's Avatar
newpony
stock cam yes
upgraded valvetrain ...as mentioned
the intake to be up gradded also
if i were to go with the boosted up setup...then ill do some fuel upgrades ...i dont want to be running lean
Old Dec 11, 2009 | 02:04 PM
newpony's Avatar
newpony
no take on the best
Old Dec 11, 2009 | 03:29 PM
mjr46's Avatar
mjr46
stock cam yes
sounds good
Old Dec 12, 2009 | 11:49 PM
newpony's Avatar
newpony
sounds good
sounds good!
is it good??
Old Dec 13, 2009 | 03:25 AM
302army187's Avatar
302army187
ugh, I HATE when people come in here with NO IDEA what they want. And just spit out combo after combo afte combo
If you want 400 at the crank, that is easy, and can pass emissions pretty damn easy.
If you want 400 at the wheels then I would go with a 351 punched out to a 408. In my state it is legal to do a engine swap and pass emissions as long as the engine you are swaping into the car is newer.
I advise you read A LOT more before you start spending money, and figure out what YOU want out of the car better.
