Engine building
Old Jan 16, 2010 | 10:53 PM
calfroper_06's Avatar
calfroper_06
Originally Posted by AdderMk2
did you disconnect the dust shield? did you remove the starter? did you unbolt the torque converter (if its auto)?
+1....Also could be hanging on the ends of the dowl pins.
As far pr oiling, i use a extra dizzy i had laying around, took the dizzy gear of and it works like a charm every time
Old Jan 16, 2010 | 10:57 PM
Lazor05's Avatar
Lazor05
That's a good idea. I have a spare dizzy so that sounds good. And what should I do in either of those two cases? It looks like the dowels may possibly be the cause but its hard to tell. I have tried jacking the transmission and engine in various locations with no luck
Old Jan 16, 2010 | 10:58 PM
.boB's Avatar
.boB
There are 6 bolts holding the bellhousing to the block. There are two small bolts holding the bottom of the block plate to the BH. There are two starter bolts through the block plate and into the bellhousing. There are two dowel pin pressed into the block that locate the BH. That's it.
If you seperate the BH from the block by 1/2" or so, that's enough for the trans snout to clear the bearing. If the angles don't match, the snout will be forced up into the splines of the clutch disc. There's a small risk of damage, but not much. It may also be hung up on the block dowels. Just pry it apart carefully.
Keep in mind that the engine is not swinging free until you seperate the BH. Once it springs free, there's a chance it will swing around and break stuff. Like fingers. That much mass can do some damage once it gets moving.
Old Jan 16, 2010 | 11:01 PM
Lazor05's Avatar
Lazor05
Ok I will just trying prying it carefully then. This is my first time pulling an engine and hundreds of pounds swaying in front of me makes me nervous so im careful. haha
Old Jan 17, 2010 | 03:48 AM
302army187's Avatar
302army187
I pulled the tran's off the bellhousing and left the bellhousing attached.
I would set the motor back onto the K-member, secure it. And climb under the car to try and free the transmission.
Old Jan 17, 2010 | 09:08 AM
sn95_331_GT_ yellow's Avatar
sn95_331_GT_ yellow
+1
thats how i did it.
a T5 weighs like 75lbs, just pull it of and drop it onto your chest to get it out.
done it a few times
Old Jan 17, 2010 | 12:15 PM
stang8689's Avatar
stang8689
you can rent the primer for free at autozone just gotta put like a $10 deposit down till you return it
Old Jan 18, 2010 | 05:13 PM
Lazor05's Avatar
Lazor05
Well I got quite a bit done today.
Old Jan 18, 2010 | 05:15 PM
Lazor05's Avatar
Lazor05
Thats just a coat of primer. Still have some touch up to do before paint.
Then I will finally get to drop in the motor. Its just a stock build but its a roller cam instead of the flat tappet I had in there. Should be done tonight if all goes well
Old Jan 18, 2010 | 06:29 PM
Bubba 95SN's Avatar
Bubba 95SN
Not the throwout bearing. Remove transmission. Seperate engine and bellhousing then remove engine. Double check for hoses and wires that may still be connected.
