need help please!!!!!!!!!!
Old Jan 20, 2010 | 04:51 PM
AdderMk2's Avatar
AdderMk2
Banned
Originally Posted by 89stangbanga
Not to thread jack, but if you open the valve and press down on the little pin and hardly anything comes out, that's bad right? If not very much is coming out what problem could that be?
low pressure/volume... start by replacing your fuel filter, and buying a fuel pressure gauge
Old Jan 20, 2010 | 05:45 PM
chad199's Avatar
chad199
well I tested the fuel pressure not that I think it is a spark issue tested coil today and it seems to have a on and off spark going to replace coil and coil wire see what happens and will let you guys know thanks again for all the good help chad
Old Jan 20, 2010 | 05:58 PM
AdderMk2's Avatar
AdderMk2
Banned
if you have spark that comes and goes, typically in these cars it is NOT the coil...
usually the PIP in the distributor, followed by the TFI module on the passenger fenderwell
Old Jan 20, 2010 | 06:45 PM
MustangBradley's Avatar
MustangBradley
Everything AdderMk2 said in his post is correct. Unfortunately, he missed my attempt at some humor. Perhaps if he reads my post more carefully, he will see that I agreed with mjr46 about the pressure gauge.
That said, a split second push of that valve will tell you IF you have a pressurized fuel rail. How much pressure? Have no idea which is why the pressure gauge is the way to go.
http://mustangefiswap.blogspot.com/
Old Jan 20, 2010 | 11:41 PM
dreamer1uk's Avatar
dreamer1uk
Still, pressing the schrader valve down for a split second is enough to cause a fire if your stupid enough to this on a hot engine...
And heres a TFI and PIP testing procedure
http://351winsor.com/joel/Ignition_Systems/tfi2.html and
http://sbftech.com/index.php/topic,588.0.html
Hope these help!
Old Jan 21, 2010 | 09:08 AM
MustangBradley
Spraying hot headers with fuel is indeed a fire hazard. But that is not the situation here. Go back and read the original post in this thread. He can't even get the car started. Therefore, no hot engine. But this is all moot since you and Adder have pointed out that his problem is probably PIP or TFI related.
Lawyers are here on earth to protect the stupid from themselves. Chainsaws have warnings not to grab the running saw by the moving chain. Why? Because someone out there will probably do it then sue.
