need help please!!!!!!!!!!
Old Jan 19, 2010 | 05:52 PM
chad199's Avatar
chad199
Default need help please!!!!!!!!!!
Hi my name is chad I just got a 95 mustang gt after it sits overnight it takes forever to start after that it will start easy it runs fine no other problems I had the codes checked nothing I was thinking I should start by changing the fuel filter maybe plugs I can hear the fuel pump running just seems as it is not geting gas but once you get it to start runs fine allday even after sitting for hours any help would be great Thanks
Old Jan 19, 2010 | 06:31 PM
MustangBradley's Avatar
MustangBradley
One test to perform is this. When you try to start it for the first time, turn the key into the on position so the fuel pump primes for two seconds. Turn the key off. Turn the key on again to re-prime. Turn if off. Turn it on again but this time, try to start the car. If it does not want to start, your problem is probably not fuel related. Could be timing. Have you adjusted that any?
Old Jan 19, 2010 | 07:39 PM
chad199's Avatar
chad199
havent checked the timing have tryed to prime with the fuel pump just weird that once you get it to start it runs great Thanks for your help
Old Jan 19, 2010 | 08:10 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
don't be so sure of that^^^^^^^^^^^^^^, you need to put a fuel pressure gauge on and check for leak down, and DO NOT TOUCH THE TIMING!!!!!!!!!!! CHECK FOR leak down first with a gauge on the test port, I bet you have leakdown...once you verify that then we can help pinpoint where the leakdown is
Old Jan 19, 2010 | 10:26 PM
chad199's Avatar
chad199
thanks I will get a gauge and check it hope we can pinpoint it thanks again
Old Jan 19, 2010 | 10:44 PM
OnyxCobra's Avatar
OnyxCobra
If you do what MustangBradley says and it helps then you could have the same problem I had, the valve in the fuel pump was stuck open and allowed the fuel pressure to drop as soon as the car was turned off.
Old Jan 20, 2010 | 08:27 AM
MustangBradley
mjr46 put a finer point on it than I did. I asked if you had adjusted the timing only because it seems so many people adjust their timing looking for a few more horsepower and then adjust it wrong. His idea of a pressure gauge is the more sophisticated way, and the safer one. Spraying oneself with gas is the quick and dirty way. Hope you don't smoke!
http://mustangefiswap.blogspot.com/
Old Jan 20, 2010 | 04:35 PM
AdderMk2's Avatar
AdderMk2
Banned
and also doesnt tell you jack diddly ****..
pressing on the schrader valve and spraying fuel everywhere is not only dangerous, messy, and down right STUPID... its also not accurate in ANY way.
I HIGHLY doubt that YOU can tell the difference between 20PSI and 39PSI with a spary from a valve core... Also, the gauge helps clue you in, not only on a PRESSURE, problem.. but also a VOLUME problem.
If fuel pressure drops while the engine is under load... you have a volume issue. sadly, half of the hacks on this site STILL havent got a clue what that means.
Old Jan 20, 2010 | 04:38 PM
FivePointOhh's Avatar
FivePointOhh
in limbo
+1 ^^
Old Jan 20, 2010 | 04:44 PM
89stangbanga's Avatar
89stangbanga
Not to thread jack, but if you open the valve and press down on the little pin and hardly anything comes out, that's bad right? If not very much is coming out what problem could that be?
