little help here
Old Jan 22, 2010 | 02:56 PM
mustangsneverdie's Avatar
mustangsneverdie
Question little help here
Lately it feels like my car is losing power(hp) around 20 or more. I'm pretty sure it's a fuel issue,but everytime I hook the f/p guage up to it,it runs perfect. I'm not sure if it would be the pump,injectors, or regulator.Has anyone had a problem like this or heard of something like it.
Old Jan 22, 2010 | 03:02 PM
FivePointOhh's Avatar
FivePointOhh
in limbo
are you checking FP while under load? or just at idle/revving?
Old Jan 22, 2010 | 03:05 PM
mustangsneverdie
under load
Old Jan 22, 2010 | 03:17 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Leave the gauge connected, problem solved
Old Jan 22, 2010 | 06:47 PM
mustangsneverdie
ok one more ques.
Blue: blinker and brake light, red:tag lights and the arrows are where the wires intersect
I know you can't see very well, but I need a little help. The right blinker and brake light doesn't work and I cant tell if it would be a break in the wire,but as I was reading the diagram I got to thinking that it might be because both of the tag light were blown but I'm not sure.Can anyone correct me?
Old Jan 22, 2010 | 07:29 PM
dreamer1uk's Avatar
dreamer1uk
I would run my own ground to the problem bulbs and see if they operate or check for voltage going to them with a test light.
Ill try to find a wiring diagram and post more info for you later
Old Jan 22, 2010 | 07:41 PM
mustangsneverdie
they have a ground,the tail light works but brake light and blinker doesn't(this is on an expedition btw) it has 3 wires:ground,minor(tail light),and major(blinker and brake)
Old Jan 22, 2010 | 10:45 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
so trace the power side and see where the power is being lost
Old Jan 23, 2010 | 02:26 PM
mustangsneverdie
so it turns out I was right,there is definintely something wrong with my car just not sure as to what it is. I went to the track today and ran slower than an auto covertible. my first run was a 15.74 @ 89, 2nd run:16.03 @ 86 3rd run:16.02 @ 85 i'll have a vid in a little while
Old Jan 23, 2010 | 02:27 PM
mustangsneverdie
