Question
Old Jan 26, 2010 | 07:56 PM
im_stuck_in_iraq's Avatar
im_stuck_in_iraq
Default Question
Professional Products Polished Typhoon Intake Manifold (86-95 5.0L)
http://www.americanmuscle.com/typhoo...-polished.html
ORR
Edelbrock Performer RPM II EFI Intake Manifold (86-95 5.0L)
http://www.americanmuscle.com/edelbr...ldii-8695.html
ORR
Edelbrock Performer EFI Intake Manifold (86-95 5.0L)
http://www.americanmuscle.com/edelbr...fold-8695.html
HELLLP
Old Jan 26, 2010 | 08:08 PM
zebo87's Avatar
zebo87
i would say the edelbrock edelbrock. im not 100 percent but i think it is the best for when you do heads and cam which you should do soon if youre doing an intake swap.
Old Jan 26, 2010 | 08:15 PM
im_stuck_in_iraq
I will eventually but i want it to look good and have more performance. Which edlbrock?? Rpm II? or performer? The professional products look sweet tho man.
Old Jan 26, 2010 | 08:51 PM
Bubba 95SN's Avatar
Bubba 95SN
PP is imitation of rpm11. Uses same gaskets. Rough casting inside. Can be sanded out. Used die grinder and polishing kit on one.
Old Jan 26, 2010 | 08:54 PM
im_stuck_in_iraq
so edlbrock? i use a die grinder and a polishing kit.. whats a die grinder sorry.
Old Jan 26, 2010 | 09:00 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
THE PP intake is not a copy of the rpm II but a copy of the original rpm, I just bought the rpm II for my 89 and the casting is a much finner finished product then a PP typhoon, in order for the typhoon to be a bolt on and go deal, it really needs to have the ports /castings cleaned up and ports squared off, it is by far a finsished product, I went with the edelbrack as it was a more finished product, but still can have clean up done to just not as much needed
Old Jan 26, 2010 | 09:13 PM
AdderMk2's Avatar
AdderMk2
Banned
I have a TFS intake that MJR decided not to tell me that he WASN'T going to buy it...
Old Jan 26, 2010 | 09:44 PM
mjr46's Avatar
mjr46
only reason I bought the eddy was it matched up to the ports on the heads good and I was trying to resolve an issue with the intake lower not sealing, and this past week I had another car in with a tfs intake that was off it and I tried a test fitment of it which was the key reason I decided against it, the ports once I set it on there were sized larger then the edelbrock ports on the heads. I wanted a smooth transition and this whole issue solved, otherwise I'd of went with the tfs set up, don't feel bad, I had a local friend offering me his ported older RPM set up for half the price of new and i turned it down too, as I had spent 2 months here and there trying to solve the issue with the car.
Old Jan 27, 2010 | 06:16 AM
AdderMk2's Avatar
AdderMk2
Banned
coulda told me though.....
Old Jan 27, 2010 | 06:44 AM
mjr46's Avatar
mjr46
give me a chance next time, I just , meaning just got it, between work, physical therapy and a new addition to the family things are hectic, in fact I've yet to tell some other people waiting on me the same thing, I apologize if you got offended
