injectors
You have to get the different MAF when changing injectors. Injectors are NOT going to increase your power unless the ones you have now are maxing out the duty cycle.
I think you need to do more research.
I found a chart once upon a time that had the different sizes and there colors and limits! cant remember might try to find it again and post it on here!
but yeah stock engine and injectors work great, if your wanting a little boost just get a hypertech chip and you`d notice some differance, and also even an adjustable FPR will help make some gains on a stock engine!
Simple basic note more fuel air and timing more power, but there is a limit to every little tweek!
IF you dont mind sharing what did you set your base timing to?
