Sensor help!!
Old Feb 14, 2010 | 10:59 PM
87MustangLX's Avatar
87MustangLX
Default Sensor help!!
I have an 87 lx with the 5.0 swap, 5spd. the guy that performed the swap never hooked up the maf or egr, etc. the car revs up and down when cold..ya ya. there is throttle lag.
I ran a 14.7 the 1st time i took it to the track
Is there a decent performance difference with the fixing of these?
if so is there a guide to hooking these up?
Old Feb 14, 2010 | 11:03 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
first thing to know would be ...what year harness did he install??? are you sure he didn't use a SD harness???
Old Feb 14, 2010 | 11:05 PM
87MustangLX
thats a good question, i never got the details on his swap. how can i tell?
Old Feb 14, 2010 | 11:12 PM
dreamer1uk's Avatar
dreamer1uk
Look to see if it has a MAF or a VAF.....
Old Feb 14, 2010 | 11:16 PM
87MustangLX
well the guy has a cone airfilter directly off the throttlebody
Old Feb 14, 2010 | 11:25 PM
dreamer1uk's Avatar
dreamer1uk
Is there anytype of electrical connection behind the cone filter? Hopefully the guy had sense to mount the cone filter onto the MAF or VAF and somehow bolt that to the TB....
A pic would help.
Without the MAF, the vehicle would run terrible, so too if it was missing the VAF which is used as part of the SD formula.
CEL on?
Old Feb 14, 2010 | 11:35 PM
87MustangLX
there are a few connections, unhooked of course, laying on the intake. I haven't looked too much, but what i've seen is the egr has nothing hooked up to it. the cel is not on, but as i mentioned the car basically runs like it's carb'd when its cold, the swinging of the rpms, the wanting to die. the major lag with the throttle and rev. I will get a pic up tomorrow.
Old Feb 15, 2010 | 07:35 AM
projectresto83's Avatar
projectresto83
M.A.D. Motorsports
Get some pics.....
Old Feb 15, 2010 | 08:25 AM
mjr46's Avatar
mjr46
CEL on?
VAF ?????? vane air flow sensor??? if so SD cars did not use such, the main input for load on a SD car is the MAP sensor for load as well as a few other sensors
Old Feb 15, 2010 | 09:40 AM
dreamer1uk's Avatar
dreamer1uk
Yes you are right from a certain point of view
However some Fords do use the VAF DEPENDANT on engine application and the kind of sensors employed for EEC IV systems for use in the SD system. I can photo copy that from my Fords EEC IV we use for college if you like
OP - mjr46 is right on you having a MAP and not a VAF so i apologise fir the misinformation.
