Sensor help!!
Old Feb 15, 2010 | 11:06 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
I know lots of cars had VAF'S....alot of older bmw's I work on as well as fords had such.........just that the fox body never was equipped with such..........no harm no foul, I see your edit
Old Feb 15, 2010 | 11:46 AM
87MustangLX's Avatar
87MustangLX
ill get a few pics up here in about an hour
Old Feb 15, 2010 | 12:54 PM
87MustangLX
Old Feb 15, 2010 | 02:05 PM
mjr46's Avatar
mjr46
is the egr sensor connected?? looks like one of the connectors for such and the other connector appears due to the fact you are holding heater hoses in your hand that they did not install the proper metal coolant pipes which house the ECM'S ECT sensor = coolant temp sensor = vital input for cold start running as well as an input to let ecm know when car is at operating temp to switch from open loop to closed loop.......I see no maf connector so it may be safe to assume the car Is SD = speed density, pulling the cars ecm and getting a code off it can further verify that
Old Feb 15, 2010 | 02:28 PM
dreamer1uk's Avatar
dreamer1uk
mjr46 did a great job in identifying those conntectors. I would do exactly as he says and get the ECT hooked back up once you have the correct lines.
Im going to ASSume the EGR isnt hooked up seeing as theres a vacuum hose missing from it also.
I would also recomend a proper intake system too, lol.
Old Feb 15, 2010 | 02:42 PM
87MustangLX
yea, im not too smart when it comes to electrical. I just can't believe i got a 14.7 out of that. Can the local autozone help me out? I've been to autozone before about specific mustang problems and they told me to go to the dealership lol.
Old Feb 15, 2010 | 02:45 PM
dreamer1uk's Avatar
dreamer1uk
Im not sure they will carry the coolant hose you need and the fitting for the ECT. Just call them and ask.
No matter what autoparts store you go to, you will get some people who are somewhat clueless and then there is some out there who know what there talking about for specific brands of vehicles
Old Feb 15, 2010 | 02:47 PM
87MustangLX
i appreciate the help, thank you guys
jwog666
Dec 27, 2021 08:09 PM
mrtrodonet
Sep 19, 2020 03:12 PM
Dathan
Oct 5, 2015 05:52 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
TfcCDR
Sep 14, 2015 12:08 PM
