five lug conversion
Old Feb 21, 2010 | 03:35 PM
  #21
5.0stang123's Avatar
5.0stang123
Yes so why is this a problem?
Old Feb 21, 2010 | 03:40 PM
  #22
motorman524's Avatar
motorman524
MF Informant
Originally Posted by motorman524
I mean the wheel bearing usually creates a problem. It won't allow the wheel to be mounted because it sticks out really far. Or did you use sn spindles, rotors and calipers up front?
This.
Old Feb 21, 2010 | 07:56 PM
  #23
The Stang Mang's Avatar
The Stang Mang
It's kind of difficult to explain unless you're looking at one, but on the rotor surface where the wheel bolts up to is a sqared off edge, and on the wheel it has a slight bevel, so unless you create a matching bevel on the rotor, the wheel won't bolt up squarely creating some pretty serious issues. But like i mentioned before its not that difficult to take some meat off the edge and machine a matching bevel to the wheel, solving the problem. It took about 5 or 10 mins on an old brake lathe to make it work.
So either you could get the kit from Lmr and do a little work, or piece together parts using the sn95 spindles which require no work (from what i can tell, i never went this route). In my opinion the kit is worth it, i like knowing im usuing quality parts and not having to piece parts together. But if you're looking to save some cash, junkyards and craigslist. Hope this helps.
Old Feb 21, 2010 | 08:07 PM
  #24
5.0kid's Avatar
5.0kid
the axles idk id did a 9 inch setup in a 8.8 rear but the front you can use 87-89 mark 7 rotors and they fit perfectly in the front brackets
Old Feb 21, 2010 | 08:08 PM
  #25
5.0kid's Avatar
5.0kid
they are the same as the stock oem brake rotors just with 5 lugs
Old Feb 21, 2010 | 09:04 PM
  #26
motorman524
MF Informant
I have a brand new, never used set with new seals and new pin that I'll let go for cheap if someone wants them
Old Feb 21, 2010 | 09:26 PM
  #27
symonds86's Avatar
symonds86
my buddy and i went with sn parts front and rear on my 88 and his 87, found them at the local u pull it yard was $150 for front spindles, front calipers, rear axles, rear calipers and backing plates. then we bought new pads and rotors all the way around, dont remember what that cost. this makes wheel stick out i think a half inch father on each side but it worked for us. this is mine with a 17x 10.5 on the rear
Old Feb 21, 2010 | 09:29 PM
  #28
motorman524
MF Informant
^ What exactly did you have to do to get that 10.5 to fit back there? I have been on the fence about deep dishes(for the rear only) but can't pull the trigger because I can't get a good answer on what exactly to do.
What year was the car you pulled your parts off of?
Old Feb 21, 2010 | 09:39 PM
  #29
symonds86's Avatar
symonds86
the donor was a 96. i had to roll the rear fenders, no quad shocks with the axles being a little wider i didn't have any clearance issues with the back of the tire and the inner fender. i donno if i would have with the stock width. i think im gonna have to run dumps for exhaust but donno yet
Old Feb 21, 2010 | 09:40 PM
  #30
symonds86's Avatar
symonds86
also am running a 275 40 17 tire kinda narrow for a 10.5 rim but i think the look and will work ok
