five lug conversion
Old Feb 19, 2010 | 12:03 AM
19stang88's Avatar
19stang88
Default five lug conversion
what model and year car can i take the axles and front lugs out of? I want to know before i pull the parts. thanks in advance
Old Feb 19, 2010 | 06:35 AM
motorman524's Avatar
motorman524
MF Informant
I'd use/used 94-95 Mustang.
Old Feb 19, 2010 | 06:35 PM
19stang88's Avatar
19stang88
does it bolt right up or do i need to do anything special to it?
Old Feb 19, 2010 | 06:44 PM
motorman524
MF Informant
For the most part. Find a good write up and use it. This is covered A LOT.
Old Feb 19, 2010 | 08:14 PM
primetime5.0's Avatar
primetime5.0
when I first did it I used ranger axles, you can buy svo rotors from a parts store, it would be the cheapest way to convert to 5 lug, but your wheel choice would be limited
Old Feb 19, 2010 | 09:14 PM
The Stang Mang's Avatar
The Stang Mang
I used the kit from Late Model Restoration. It was 400 bucks but came with everything. It came with brand new yukon axles, new rotors, bearings, all that stuff. Was a good kit.
Old Feb 19, 2010 | 09:18 PM
motorman524
MF Informant
^ How'd you get the front rotors to work with those wheels?
Old Feb 19, 2010 | 09:22 PM
The Stang Mang
How did i get them to work? If you're referring to clearance issues, there wasn't any, i believe they're just stock size rotors.
Old Feb 19, 2010 | 09:26 PM
motorman524
MF Informant
I mean the wheel bearing usually creates a problem. It won't allow the wheel to be mounted because it sticks out really far. Or did you use sn spindles, rotors and calipers up front?
Old Feb 19, 2010 | 09:29 PM
tolbert67's Avatar
tolbert67
I ordered mine from Jeggs... about 4 years ago...it was the ranger axel/spindle kit and was only 350.00.
