vin number problem
Old Mar 5, 2010 | 03:11 PM
84fox5.0's Avatar
84fox5.0
Default vin number problem
hey guys im having a hard time hear telling if my shell is a lx or gt..all sites say that the 28 in my vin indicates a gt vert but its definately not a vert..also my title says lx/gt??
heres then vin
1FABP28 means gt??33 whats this 33 mean???GF223659
now all the gt vin decoders i found said my 8 digit should be an M but there is no M.
Im asking this as im trying to resotre this car and buy exhuast but i dont wanna buy lx exhuast and find its a gt unless it doesnt make a difference in the 1986 years...thanks for all the help guys
Cory
Old Mar 5, 2010 | 04:45 PM
ALMOST STOCK's Avatar
ALMOST STOCK
The 2 Digit code after 28 means (used to verify vin has been recorded correctly)
1-UNITED STATES
F-FORD
A-FORD/PASSENGER
B-ACTIVE BELTS
P-FORD PASSENGER
28-3 DOOR HATCHBACK
M-302 8 CYL 5.0L
2-DIGITS (used to verify vin has been recorded correctly)
G-1986
F-DEARBORN ASSEMBLY PLANT
223659-SEQUENTIAL BUILD NUMBER
Old Mar 5, 2010 | 04:48 PM
84fox5.0's Avatar
84fox5.0
well theres a problem there is no M in the code infact this used to be a v6 if that helps
Also does anyone know if the v6 had same springs as the 4 cylinders??
Old Mar 5, 2010 | 05:02 PM
ALMOST STOCK
Not sure of the code for a 6 cyl
M= 5.0L V8
A= 2.3L I-4
Old Mar 5, 2010 | 06:18 PM
projectresto83's Avatar
projectresto83
M.A.D. Motorsports
When it comes to the exhaust you don't need a GT exhaust unless you have a GT ground effects such as in ALMOST STOCK's sig. The tips are the only thing that is different. That is all said of course you are using a double hump trans crossmember and aftermarket exhausts.
Old Mar 5, 2010 | 06:28 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
86 doesn't have ground effects justin........exhaust on lx vs gt are the same, the difference on the gt's were they had cut outs for fog lights on the front nose clip.
Old Mar 5, 2010 | 06:31 PM
projectresto83
M.A.D. Motorsports
Yes this is true, I was just speaking in general terms about LX and GT differences. I had a kid in my lap moving around so I didn't want to sit and explain everything needed.
Oct 26, 2015 05:01 PM
MasterLanMan
Sep 13, 2015 08:21 PM
Sep 8, 2015 11:50 AM
