Just want a nice 400hp out of my 5.0
Old 03-06-2010, 08:21 PM
89LX5pointO
89LX5pointO's Avatar
Holy hell, THAT is sick! Anyone on here bought/installed/ran that kit??
89LX5pointO is offline
Old 03-06-2010, 08:48 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
many ways to do it , all depends what you have to spend??
mjr46 is offline
Old 03-06-2010, 09:30 PM
Mustang Boy
Mustang Boy's Avatar
Cool
i say check out the trickflow trackheat topend kit but instead of getting it just get the pieces except for the cam and go with a custom cam, then 70-75mm TB, CAI, tear down the engine bore it out to a 306 with some higher compression pistons, long tube headers, x or h pipe(your choice), a nice sounding catback, upgrade the ignition system, add in some 3.73 gears and you should be thoroughly happy
Mustang Boy is offline
Old 03-06-2010, 10:34 PM
sn95_331_GT_ yellow
sn95_331_GT_ yellow's Avatar
if your gonna go through the work of machining the block, might as well go with a 331 or 347, get some TF heads, custom grind cam and call it a day. theres your 400 no problem...
sn95_331_GT_ yellow is offline
Old 03-07-2010, 11:05 AM
89LX5pointO
I appreciate all the feedback...looks like there's endless possibilties for these Mustangs! The last 2 responses prior to this, how much am I lookin at estimated? 4k?
Old 03-07-2010, 11:39 AM
Bobert
Bobert's Avatar
that on3 kit seens to good to be true those #'s are radic
you'll probs be alot higher then 4k, in the h/c/i alone.
heads ~ 1.5k
t/b
maff
upper / lower
injectors
fuel management
its nasty when you crunch #'s
Bobert is offline
Old 03-07-2010, 02:06 PM
Mustang Boy
Cool
yea 4k is kind of low but if you really scrounge around you may be able to get most of the parts used which will save you some money. id put the estimates closer to 7-8k to do everything and the supporting mods. now the good thing is you dont have to do them all at once you can do things as you get the money. like gears could be done first, then exhaust, then piece together an HCI and when you take it to the machine shop you can have it bored out and new pistons(or stroker kit) put in then install the HCI since its all apart already.
Old 03-07-2010, 02:23 PM
Riceinator
Riceinator's Avatar
Originally Posted by NoGo95GT
Does anybody actually have any experience with this kit? Is it just like one of those ebay kits or is it an actual quality kit?
Riceinator is offline
Old 03-07-2010, 03:13 PM
luckythirteen13
luckythirteen13's Avatar
so far it seems to be a quality kit. A lot of guys on corral as well as theturboforums.com are having great luck with it
luckythirteen13 is offline
Old 03-08-2010, 06:29 PM
NoGo95GT
NoGo95GT's Avatar
^^^^^Agreed. While the his #'s seem a bit high, a turbo can make some real nice numbers. And if I am not mistaken, he upgraded his kits' headers from the crack-prone 304ss headers to mild steel for extended durability. When he makes a kit for the 94-95 cars, I'm jumping in
NoGo95GT is offline
Quick Reply: Just want a nice 400hp out of my 5.0
