any one using a comp cam custom grind cam
Part #: 35-000-8
Grind #: 3613B/3299S HR110+4
Duration @ .050": 230/236
Lift w/1.6 Ratio: .513/.526
LSA: 110
Advance: +4
this is the one they recommend for my set up. does any one run this cam if so how does it proform for you.
does anyone have a sound clip
LSA: 110
Advance: +4
Make:
ford
Model:
mustang lx convetable
Year:
1987
Weight:
3000 lbs. or whatever a vert lx is
Axle Ratio:
3.73
Transmission Type:
Manual
Tire Height:
245/45 r17
Torque Converter Stall Speed:
N/A
ENGINE INFORMATION
Engine Block Type:
Ford
Engine Size:
347 c.i.
Number of Cylinders:
Bore:
30 over
Stroke:
N/A
Compression Ratio:
10:1 or 10.5:1
Piston Type:
flat top
Connecting Rod Length:
N/A
Intake Manifold Type:
rpm air gap
Cylinder Head(s) Brand:
pro comp
Head Runner Volume:
200
Ported Heads:
No
Intake Valve Size:
2.05
Exhaust Valve Size:
1.60
Rocker Arm Type:
Full Roller
Rocker Arm Ratio
1.6:1
Timing Set Type:
Chain
Timing Set Fixed/Adjustable:
Adjustable
Exhaust Headers:
Yes
Exhaust Type:
Dual
RPM Range Low:
1800
RPM Range High:
6500
Nitrous Oxide:
mybe 100 to 150 shot
Horsepower from Nitrous:
N/A
COMPUTER CONTROLLED VEHICLES
Vehicle Computer Type:
None
Speed Density Sensor:
Don't Know
Mass Air Sensor:
Don't Know
FUEL DELIVERY
Fuel Type:
Pump Gas
Fuel Octane Rating:
93
Carburetor:
Yes
Carburetor Size:
650
ford
Model:
Year:
1987
Weight:
Axle Ratio:
3.73
Transmission Type:
Manual
Tire Height:
245/45 r17
N/A
ENGINE INFORMATION
Engine Block Type:
Ford
Engine Size:
347 c.i.
Bore:
30 over
Stroke:
N/A
Compression Ratio:
10:1 or 10.5:1
Piston Type:
flat top
N/A
rpm air gap
pro comp
Head Runner Volume:
200
Ported Heads:
No
Intake Valve Size:
2.05
Exhaust Valve Size:
1.60
Rocker Arm Type:
Full Roller
Rocker Arm Ratio
1.6:1
Timing Set Type:
Chain
Adjustable
Exhaust Headers:
Yes
Exhaust Type:
Dual
RPM Range Low:
1800
RPM Range High:
6500
Nitrous Oxide:
N/A
None
Don't Know
Mass Air Sensor:
Don't Know
FUEL DELIVERY
Fuel Type:
Pump Gas
Fuel Octane Rating:
93
Carburetor:
Yes
Carburetor Size:
650
depends on what your goal is with the combo?? I run a ported rpm air gap and a biggs performance stage 5 750 holley hp that flows 780cfm.......mine is both a street strip car, most people tend to use a victor jr intake but the cam and heads would be the supporting factor in most cases but there are always exceptions to that
my cam is mid 5ish for lift on my 347 and thats too small. www.camshaftinnovations.com
go talk to him, he will set you up with a good cam
