Headlight Adjustment Panel ???'s
How much of the studs do you guys have sticking through on the headlight to be able to get the nut on and tighten it down? I can get the outsides through just fine but the 2 inside studs barely come through the header panel. I have When I force it in enough to get the bottom nut on it causes the panel to bend enough to where the adjustment screws don't want to stay in the headlight. I have thoguht about trimming the header panel down to see if it will help but I don't think there is much to trim. Its the big square in the upper inside corner on the header panel where the inside adjustment screw comes through that is causing the problem...
Ideas???
Ideas???
You would think lol but they only go in one way. IDK what is up with it but it seems like the inside adjustment part that is angled just doesn't angle enough. OO well I am just going to cut the square part that it goes through out since it doesn't affect its mounting.
