ignition problems
Old Mar 11, 2010 | 05:26 PM
humblemustang21's Avatar
humblemustang21
Default ignition problems
Hey guys I have a 1994 cobra and am having ignition problems such as the car just shuts off on its own and will not restart due to no spark and all ignition parts have been replaced some times i will regain spark and it fires right up and will run fine for a little while or just until i turn the car off any ideas on what this might be would be of great help.
Old Mar 11, 2010 | 06:19 PM
AdderMk2's Avatar
AdderMk2
Banned
by "all ignition parts have been replaced" what exactly do you mean?
Spark plugs
Wires
Cap
Rotor
Coil
TFI module
Distributor
??? anything in that list that you HAVENT replaced???
Old Mar 11, 2010 | 07:22 PM
humblemustang21
nope all these things have been replaced within the past 3 months
Old Mar 11, 2010 | 07:57 PM
AdderMk2's Avatar
AdderMk2
Banned
when you replaced the distributor, what did you install
dont make me keep asking questions... Overwhelm me with details... please
Old Mar 11, 2010 | 09:12 PM
humblemustang21
i replaced all the electronics inside the distridutor as well as the cap and rotor, ignition control module, coil, plugs, wires and tps and those were all replaced last month and the plugs and wires were done about three months ago i have fuel presure and it is getting into the cylinders just no spark at all. The rotor is turning while i crank the car all parts are stock replacement except the coil, cap, rotor,and wires they are all msd and i tried the stock coil and had no changes.
Old Mar 11, 2010 | 09:39 PM
AdderMk2's Avatar
AdderMk2
Banned
How to solve an EFI no Start
Old Mar 11, 2010 | 09:51 PM
humblemustang21
thank you i will try this in the morning and see what i get
Old Mar 14, 2010 | 10:21 PM
humblemustang21
Ok so i have ran all the test described in the link that was posted and even though some parts did not need changing out i did it anyways such as the coil and ignition control module i also replaced the battery and now the car will crank and run for about 1to 2 miles then loses spark again and will not run untill it cools back down to ambient temp also i was wondering if any one knows what the resistor/diode? is that is mounted to the back side of the bracket for the coil because i changed it out with the closest thing i could find at the parts store and then the car would run like it is now any more ideas on this issue would be greatly appreciated. Also replased the three relay boxes in the fuse box under the hood.
Meystang
Sep 25, 2015 04:05 PM
jessicarabbit
Sep 25, 2015 12:41 PM
pimp2303
Sep 17, 2015 08:45 PM
TfcCDR
Sep 14, 2015 12:08 PM
Wombatnation
Sep 13, 2015 09:16 PM
