First Time Poster, Time sensitive question.
Old Mar 21, 2010 | 09:11 PM
jmabrao's Avatar
jmabrao
Default First Time Poster, Time sensitive question.
Hey all first time poster here, I have a opportunity to pick up a 1989 Mustang LX 5.0 for 1,200.00 Car runs great has plenty or power, drives nice and firm. The only thing is it is smoking blue a little bit. Do you guys think it is worth it to pick it up. Or do you think I should hold off. I need to make a decision tomorrow.
Thank you all for your time
Joel
Old Mar 21, 2010 | 09:14 PM
86 5.0L's Avatar
86 5.0L
sounds like worn seals, expect oil consumption.
Old Mar 21, 2010 | 09:17 PM
jmabrao's Avatar
jmabrao
Yea I kinda figured that and I can deal with adding oil every once and awhile. I'm just curious if you guys think it is a good buy.
Thank you for the quick response
Joel
Old Mar 21, 2010 | 09:21 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
https://mustangforums.com/forum/5-0l...bers-read.html
Old Mar 21, 2010 | 09:22 PM
capri debris's Avatar
capri debris
I say buy it... valve stem seals can be replaced without pulling the heads, no biggy.
If everything else seems to be good on the car, don't let a little blue smoke keep you from buying it.
Old Mar 21, 2010 | 09:23 PM
TrimDrip's Avatar
TrimDrip
FudgeDrip
blue smoke is not a problem until you quit seeing it. Then you have problems
Old Mar 21, 2010 | 09:24 PM
Traumaside's Avatar
Traumaside
Prolly has a headgasket going with blue/white smoke out the back. 1,200 is an amazing deal even if it does has a blown headgasket. Is it an LX/Coupe(trunk) or LX/Hatchback. An LX coupe is the most sought after style and has a much higher value. Also check the chassy around all aspects of the car for rust. Could be rusting through. See if you can get a detailed description of what the dude has done to the car. It allways sucks going through and finding out whats been done to it. $800 to have a mechanic fix that head gasket, or you can DIY for $120 and a full days work. Id jump on that offer in a sec, call me at 518-892-0727 if you want to discuss it furthur, because this deal seems too good to be true
Bobert's Avatar
Bobert
yea im more of a mechanical person, so its stright, a 5 spd, interiors nice with a solid body and floor
id buy it
pooched motor = good reason to upgrade
Old Mar 21, 2010 | 10:04 PM
jmabrao's Avatar
jmabrao
Thanks for all the replies guys. I will be purchasing the car tomorrow. I forgot to mention it is a 5 speed as well.
Old Mar 21, 2010 | 10:18 PM
mjr46's Avatar
mjr46
Probably not, blue indicates oil burn, most likely a ring/cylinder wear issue or valve seal issue....heavy white smoke like clouds would indicate head gasket, coupled with coolant loss.
