A few quick nitrous questions.
Old Mar 24, 2010 | 04:37 PM
The Stang Mang's Avatar
The Stang Mang
Default A few quick nitrous questions.
Im gonna be running a 100 shot on my car,
What plugs should i run?
Will the stock fuel pump work fine? If not what pump should i get?
Thanks in advance.
Old Mar 24, 2010 | 05:43 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
wet or dry kit?? with a 100 shot I run stock heat range plugs
Old Mar 24, 2010 | 05:46 PM
The Stang Mang
I knew i forgot to mention something.
Its a wet shot.
302army187's Avatar
302army187
its a good idea to upgrade your pump. good insurance.
Old Mar 24, 2010 | 09:34 PM
luckythirteen13's Avatar
luckythirteen13
the stock pump cant support an additional 100hp. pumps are cheap might as well get the swap over with
Old Mar 25, 2010 | 01:56 AM
mxrider426's Avatar
mxrider426
mjr46 for a 100 shot what do you set your timing at
Old Mar 25, 2010 | 10:00 AM
g3mustang's Avatar
g3mustang
i think to start out base timing is fine 10*
Old Mar 25, 2010 | 10:15 AM
302army187's Avatar
302army187
drop 2 degrees of timing for every 50hp of shot, starting at 100shot. so for a 50shot there is no real need to drop your timing, at 100shot drop atleast 2 degrees, 150 shot atleast 4 degrees, ETC
that is just a guide line. All cars are different. my car likes a little more timing on the bottle.
Old Mar 25, 2010 | 05:15 PM
The Stang Mang
So should i be able to run stock plugs? If not what plugs should i get?
Old Mar 25, 2010 | 05:54 PM
mjr46's Avatar
mjr46
I error on the safe side and run total at 30-32 and I also run race gas 110+ octane, but then again I'm running a 347 with already 10.5 to 1 compression
Florida Regional Chapter
Sep 30, 2015 08:04 PM
treesloth
Sep 28, 2015 07:03 AM
Sep 25, 2015 06:30 PM
