question about a vortech v1 on my 347stroker
Old Mar 31, 2010 | 01:42 AM
89 mustang's Avatar
89 mustang
Question question about a vortech v1 on my 347stroker
ok u guys i ended up getting a vortech v1 be for looking into it first so my question is how good would this work on my 347 set up right now?
set up.
347 stroker
10,1 compresion
comp XFI 236 cam.
Trick Flow Hi port heads with 2.08 intake valves and port job.
mac 1 3/4 long tubes, pro chamber 3" all the way to the tail pipes.
Trick Flow R intake
75mm TB 76mm MAF sensor calibleted for the 30lb injectors
255-fuel pump
i think thats about it what do u guys think? would my cam work and would the 30lb's hold up with the charger or do i need bigger injectors? I see people that run superchargers with no MAF sensor. y?
Old Mar 31, 2010 | 01:53 AM
TrimDrip's Avatar
TrimDrip
FudgeDrip
those injectors are to small. You need to get a hold of a fmu for now. Or upgrade to bigger injectors and get a tune.
the no maf thing is a speed density set-up like found on a 87 mustang for example
Old Mar 31, 2010 | 02:08 AM
89 mustang's Avatar
89 mustang
i do have the vortech FMU.
Old Mar 31, 2010 | 02:17 AM
TrimDrip's Avatar
TrimDrip
FudgeDrip
you will need to take the cover off of it to find out which disc is in it. Then find out which one you need. I wish i could tell you but, I am not sure. I would think a 6:1 for that set-up but, I am not sure. Honestly, I would probably call vortech to see what size disc they recommend.
I also think Summitt sales the Vortech disc kits, they may know as well.
here are the disc sizes
12:1 = 2.72" Diameter disc, 10:1 = 2.47", 8:1 = 2.22", 6:1 = 1.85", 4:1 = 1.59"...
Old Mar 31, 2010 | 10:11 AM
89 mustang's Avatar
89 mustang
oh i see ill give them a call and see what i need. thanks
Old Mar 31, 2010 | 04:03 PM
92SSP331STANG's Avatar
92SSP331STANG
I do know that the more displacement, the less boost. May need larger S/C for more
boost....(just my 2 cents)
Old Mar 31, 2010 | 04:10 PM
5.0kid's Avatar
5.0kid
umm block? and you wont be running too much boost with 10:1 unless you plan on race gas anything over 10psi and I think your pushing it.
Old Mar 31, 2010 | 04:11 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
Is this a stock block engine? If so that V1 in a 347 will make plenty of power to make the two halves of the block go in two different directions. You will need at LEAST 42 lb injectors and a MAF and a tune. I am not a fan of FMU's but that's just me. If everything is working together you have an easy 500+ at the wheels.
Old Mar 31, 2010 | 04:45 PM
5.0kid's Avatar
5.0kid
umm yeah I would run like 6psi max unless you want your money splitting in 2 lol and you have plenty of fuel pump. Im running 42lb injectors and 14 psi and all i got is a 255 like your self
Old Mar 31, 2010 | 11:44 PM
89 mustang's Avatar
89 mustang
yea its stock block. but i do only plan on doing 9psi max and 42lbs sounds like a good i dea. thanks for the info ill see what it dose ones its all togeather tho ill let u guys know
