what to do with my 95 gt
ok im trying to figure out what cam,injectors, and tuner to get, here is my mods:
of course its a 5.0
cobra upper and lower intake
bbk cai
70 mm tb and maf sensor
bbk full length headers
bbk h pipe
dynomax ultra flow cat back exhaust
6600 sct flash chip
gt 40 p heads
air pump eliminator
centerforce dual friction clutch
tell me what yall think i should do
of course its a 5.0
bbk cai
bbk h pipe
6600 sct flash chip
gt 40 p heads
air pump eliminator
no cam, if you NEED to do something with those garbage heads (GT40P = almost no better than E7's), get some 1.7's and retard the cam about 4*...
and the SCT chip means you should use SCT software to tune the car...
and with that lackluster set up, i bet you see 230rwhp, in which case 19#'s will do just fine...
even without the gear swap...
that would work to not to mention those heads would out flow those gt40p but at the same cost while hes in there he might as well put a good cam in there like the comp cams xe270h with the rr's then hed really show the tail lights id still do the gears that helps
how 'bout for once, just once a noob, follow the rules on where to post opinion threads, and 1 clue is, it 'tain't in da' 5.0 section...try general:https://mustangforums.com/forum/5-0l...bers-read.html
