Mickey Thomspon ET Streets tread life?
Old Apr 3, 2010 | 06:37 PM
mattlowe01's Avatar
mattlowe01
Picked them up, they are in beautiful shape. Only thing is they arn't radials, just 26x11.5x15's. What's the difference?
Old Apr 3, 2010 | 08:00 PM
nitrous_bob's Avatar
nitrous_bob
well thats a bit wide.... my car has the eibach lowering springs and i cannot run those tires
the rubbed hard on turns and just with people in the back.
not radial just means they are old skool... bias-ply
try them out but you should run all 4 bias-ply or all 4 radial, you'll notice the handling diff..... the front will be stiffer and the back will be loose
you'll definitely have to dump the quads or reverse them at the least... also might need some spacers. my buddy ran the 11.5's with spacers and was ok, i'm also assuming you have 5.5" BS on the welds... they should be
they look really good though, worst case scenario is trade the tires for a set of 26 X 10.5's
be careful if you pull the tires.... do have tubes ? if they are good tubes they are about $50 each by themselves... and the rim will have to have been drilled out for them.
you'll see a plastic round hold down nut on the valve stem... and if they have been drilled... they always need to use tubes cuz the hole will be too big now for tubeless
Old Apr 3, 2010 | 08:11 PM
Venomantidote95's Avatar
Venomantidote95
there 275/50/15`s instead of the 60s i think sounds like it! just less side wall is all and its about 2.2 in shorter tire!
Old Apr 3, 2010 | 08:36 PM
mattlowe01's Avatar
mattlowe01
Ill jack the car up and see if the quad shocks have been removed. Who knows, maybe they have. It has eibach drag launch springs in it, so I'm assuming it's had slicks on it at one point. Maybe i'll be lucky.
Old Apr 4, 2010 | 01:56 PM
mattlowe01's Avatar
mattlowe01
Jacked the carp up and went to put the wheel on, only to find out that my stud's arn't long enough for these wheels. It fits in their fine though, decent amount of clearence all the way around. Not sure if this would change when there is weight on it? I couldn't set it down. I think I'll just have good year replace the studs with longer ones since I have to bring it over there anyway to dismount and mount some tires.
Old Apr 4, 2010 | 02:33 PM
AdderMk2's Avatar
AdderMk2
Banned
When you bought the wheels, did the person give you special lug nuts for them? If you do not have the long shank lugs, you should NOT even TRY to mount the wheels
Old Apr 4, 2010 | 02:43 PM
mattlowe01's Avatar
mattlowe01
No, no lug nuts. CAn I get them at an auto parts store?
Old Apr 4, 2010 | 05:01 PM
5.0kid's Avatar
5.0kid
Ive never had one problem with shaking or swaying with my bias ply et streets i did once at the track feel sway on the top end but that was because I had the air pressure at 8.5psi I know run them at 15-18 and still have never had any sway nice tires though man
Old Apr 4, 2010 | 07:56 PM
projectresto83's Avatar
projectresto83
M.A.D. Motorsports
Call the guy back up and ask for the lug nuts.
You can also find them here, just pick which one you need.
http://www.latemodelrestoration.com/...-Racing-Wheels
Old Apr 4, 2010 | 08:03 PM
AdderMk2's Avatar
AdderMk2
Banned
http://www.summitracing.com/parts/MCG-63004/
are what you want
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
mungodrums
Sep 28, 2015 10:54 PM
