What sensor is this????
Old Apr 9, 2010 | 05:30 PM
g3mustang's Avatar
g3mustang
Default What sensor is this????
There is a sensor next to the vacum t on the fire wall behind the intake manifold... It looks like it needs a vacum line hooked up to it but there isn't one... Should there be?? And were would I get the vacum from?? I have a line open but bluged on my vacum t I could use??? Any thoughts thanks
Old Apr 9, 2010 | 05:31 PM
g3mustang's Avatar
g3mustang
Ooo and I don't have any codes
Old Apr 9, 2010 | 05:32 PM
Shelty's Avatar
Shelty
I think thats the BAP sensor, you need it
Old Apr 9, 2010 | 05:45 PM
g3mustang's Avatar
g3mustang
Were does it hook up to
Old Apr 9, 2010 | 05:46 PM
g3mustang's Avatar
g3mustang
And why don't I have not throughn a code
Old Apr 9, 2010 | 05:59 PM
mattdel's Avatar
mattdel
If you have a MAF setup, the MAP sensor becomes a BAP sensor.
If you have MAF, you don't need vacuum hooked to it. Leave it be.
Old Apr 9, 2010 | 06:08 PM
g3mustang's Avatar
g3mustang
Ok my car wAs original maf car so I will leave it be... Thanks so much I was worried...
Also when I was checking around I noticed that my PVC line is easy to pull out and put back in.... Is this normal???
Again thanks
Old Apr 9, 2010 | 06:15 PM
mattdel's Avatar
mattdel
The PVC goes down to the lower intake on the back. Sometimes when the grommet gets old they become easier to pull out, but as long as you cant hear air zinging by the grommet as its running, it should be fine.
Old Apr 9, 2010 | 06:17 PM
g3mustang's Avatar
g3mustang
Cool thanks so much for the help
jwog666
Dec 27, 2021 08:09 PM
mrtrodonet
Sep 19, 2020 03:12 PM
Dathan
Oct 5, 2015 05:52 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
TfcCDR
Sep 14, 2015 12:08 PM
